How to upgrade to the new Power and Hosting Packs 2023?
On May 29th, 2023, we included Sophos Anti-Virus for Servers for 5 mailboxes in our Plesk Power and Hosting packs without additional cost. This solution is an alternative to the existing Kaspersky Anti-Virus for Servers for 5 mailboxes.
Note: only one email antivirus can be enabled in Plesk at a time
Note:
1. If a Power/Hosting Pack license was created before March 19, 2020, you should terminate that license and create a new Power Pack license to have Sophos in the Power Pack license included .
2. If a Power/Hosting Pack license was created after March 19, 2020, and before May 29, 2023, you should upgrade that license to have Sophos included in the Power Pack license.
3. If a Power/Hosting Pack license was created after May 29, 2023, Sophos is already included.
Upgrade process for Partners
It’s possible for partners to migrate from the existing Power and Hosting packs to the newest versions with Sophos inside. It can be done via KA PC or Partner API.
The upgrade to the newest version of the Power/Hosting Pack is available via the standard upgrade wizard in Partner Central:
Upgrades an existing Key with the upgrade plan defined in the method call
Method: partner10.upgradeKey
For PowerPack:
<?xml version="1.0" encoding="UTF-8"?>
<methodCall>
<methodName>partner10.upgradeKey</methodName>
<params>
<param>
<value>
<struct>
<member>
<name>login</name>
<value>
<string>{{API_LOGIN}}</string>
</value>
</member>
<member>
<name>password</name>
<value>
<string>{{API_PASS}}</string>
</value>
</member>
</struct>
</value>
</param>
<param>
<value>
<string>EXT.12345678.0000</string>
</value>
</param>
<param>
<value>
<string>PLESK-12-POWER-PACK-2020-TO-PLESK-12-POWER-PACK-M</string>
</value>
</param>
</params>
</methodCall>
For Hosting Pack:
<methodCall>
<params>
<param>
<value>
<struct>
<member>
<name>login</name>
<value>
</value>
</member>
<member>
<value>
</value>
</member>
</struct>
</value>
</param>
<param>
<value>
</value>
</param>
<param>
<value>
<string>ADD-PLESK-HOSTING-PACK-2020-TO-ADD-PLESK-HOSTING-PACK-M</string>
</value>
</param>
</params>
</methodCall>
You can use below command to modify license Key using Partner API 3.0
As reference: documentation
For Power Pack:
PUT /30/keys/<KEY_ID_OR_ACTIVATION_CODE>
"items": [
"item": "ADD-PLESK-POWER-PACK-1M"
For Hosting Pack:
"items": [
"item": "ADD-PLESK-HOSTING-PACK-1M
Upgrade process for Retail customers
Retail customers can upgrade to the new pack at https://platform360.io.
