Articles in this section
Monitoring widget on Plesk server's home page does not detect hardware changes
Plesk for Linux kb: technical
  • Plesk for Linux
  • After a server hardware change, Monitoring widget shows wrong (old) RAM capacity.
  • The issue is not resolved if plesk ext monitoring --installation --detect-hardware-changes is executed.
Bug confirmed EXTPLESK-7999.
Until bug is fixed, use the following workaround:
  2. Delete the Monitoring cache folder:
    # rm -rf /usr/local/psa/var/modules/monitoring/cache
3 comments
Date Votes
  • Despite:
    Bug confirmed EXTPLESK-7999. A fix will be deployed within the next 2.9.x Monitoring release.
    This bug remains in monitoring 2.10.1
  • This is not solved yet on Plesk Obsidian 18.0.80 Update #7
  • Peter Sørensen the bugfix hasn't been implemented yet, but the workaround still stands and should work. If the workaround still doesn't work, please submit a ticket and we'll check with care: https://support.plesk.com/hc/en-us/requests/new
