Articles in this section
Installation of mailparse PECL package fails: re2c command not found
php pecl
  • Plesk for Linux
Installation of the mailparse PECL package for a Plesk PHP version (for example PHP 8.4) fails from Tools & Settings > PHP Settings > PHP_version > Manage PECL packages or from the command line:
# /opt/plesk/php/8.4/bin/pecl install mailparse
The build stops with the error:
PLESK_ERROR: re2c -b /tmp/mailparse/php_mailparse_rfc822.re > /tmp/mailparse/php_mailparse_rfc822.c
/bin/sh: line 1: re2c: command not found
make: *** [Makefile:209: /tmp/mailparse/php_mailparse_rfc822.c] Error 127
ERROR: `make' failed
The re2c package is not installed on the server.
mailparse defines its RFC 822 address parser in a .re file, and the build uses re2c to generate the C source file php_mailparse_rfc822.c from it. Without re2c, make cannot create that file and stops with exit code 127 (command not found). re2c is only needed while compiling the extension.
  1. Connect to the server via SSH.
  2. Install re2c.
    RHEL-based systems (AlmaLinux, Rocky Linux, RHEL, CentOS). If the package is not found, enable EPEL first with # dnf install epel-release:
    # dnf install re2c
    Debian and Ubuntu:
    # apt install re2c
  3. Run the mailparse installation again, from the Plesk interface or with the command below, replacing 8.4 with the required PHP version:
  4. Check that the extension is loaded:
    # /opt/plesk/php/8.4/bin/php -m | grep -i mailparse
