Articles in this section
agent360 error: extension module was built for another version of psutil
Plesk for Linux kb: technical
  • Plesk for Linux
  • agent360 is not transmitting data for the past 15 minutes.
  • The following error can be seen when the command agent360 test is run into an SSH session:
    Load error: version conflict: '/usr/local/lib64/python3.6/site-packages/psutil/_psutil_linux.cpython-36m-x86_64-linux-gnu.so' C extension module was built for another version of psutil (5.9.0 instead of 6.1.0); you may try to 'pip uninstall psutil', manually remove /usr/local/lib64/python3.6/site-packages/psutil/_psutil_linux.cpython-36m-x86_64-linux-gnu.so or clean the virtual env somehow, then reinstall
Conflicting file in the plugin folder.
  2. Move the conflicting file out of the folder:
    # mv /usr/local/lib64/python3.6/site-packages/psutil/_psutil_linux.cpython-36m-x86_64-linux-gnu.so /root
  3. Restart the agent360 service again:
    # systemctl restart agent360
