Articles in this section
How to create TLSA DNS record in Plesk and adjust DANE?
kb: how-to
Via Plesk CLI utility
  1. Open panel.ini via preferred editor
  2. Add the following directive:
    CONFIG_TEXT: [ext-sslit]
    allowIssueDaneCertificatesInCLI = true
  3. Connect to a Plesk server via SSH.
  4. Execute the following command:
    # plesk ext sslit --certificate -issue -domain example.com -registrationEmail jdoe@example.com-secure-domain -secure-mail -dane
  5. Execute the following command to finish the installation:
    # plesk ext sslit --certificate -issue -domain example.com -continue
Via CLI manually
  1. Create example.com domain in Plesk.
  2. Issue a Let's Encrypt certificate for this domain.
  3. Log into the server via SSH.
  4. Install hash-slinger package with the command:
    # yum install hash-slinger
  5. Find name of the certificate file for example.com domain using a command below:
    # plesk db "select cert_file from certificates where name like '%example.com%'"
    | cert_file |
    | scfygh0Pw |
  6. Switch to the /usr/local/psa/var/certificates/ directory:
    # cd /usr/local/psa/var/certificates/
  7. Using the name of the certificate file from the step №5 and the next command, generate TLSA record for mail.example.com on port 25:
    # tlsa --create --selector 1 -p25 --certificate scfygh0Pw mail.example.com
    The output was the following:
    CONFIG_TEXT: _25._tcp.mail.example.com. IN TLSA 3 1 1 f8bda51d176a1d315eeec8a53c52febedf43319bf7c7ebbccafa9e14d9616541
  8. Go to Plesk > Domains > example.com > Hosting & DNS > DNS.
  9. Press the Add Record and using the values from the step №7, created a TLSA record for mail.example.com:
  10. After install Plesk DNSSEC extension by pressing Get It Free button in Plesk > Extensions > Extensions Catalog > Categories > DNS.
  11. Enable DNSSEC for example.com domain by pressing the Sign the DNS Zone button in Domains > example.com > Hosting & DNS > DNSSEC.
    Note: Algorithm was chosen as RSASHA256
To verify the results, open https://www.mailhardener.com/tools/dane-validator, specified mail.example.com an press the Inspect button
As the result it shows the configured TLSA DNS record and reported that DANE is properly configured for mail.example.com:
