Plesk for Windows
DoNotDelete:docref
kb: how-to
Plesk for Linux
- Plesk for Windows
How to edit Plesk panel.ini
file?
Install the Panel.ini Editor from the Extensions menu in Plesk.
Open Panel.ini Editor at Extensions > My Extensions.
In Panel.ini Editor, switch to the Editor tab. If the editor is empty, do the following:
3.1.Download the panel_ini.txt file.
3.2. Open the downloaded file and copy its content.
3.3. Paste the content into the editor.
Edit the content and click Save.
