- The Softaculous tool within Plesk displays the following error once opened:
PLESK_INFO: 500 Error
Message Call to a member function dispatch() on null
Type Error
File index.phtml
Line 1 - The following error can be found in the in the
/var/log/plesk/panel.logof your server:
CONFIG_TEXT: [2023-03-23 03:44:39.714] 3036096:641b68b7ae657 ERR [panel] Call to a member function dispatch() on null:
0: /usr/local/psa/admin/plib/modules/softaculous/views/scripts/index/index.phtml:1
include()
1: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/View.php:157
Zend_View->_run(string '/usr/local/psa/admin/plib/modules/softaculous/views/scripts/index/index.phtml')
2: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/View/Abstract.php:888
Zend_View_Abstract->render(NULL null)
3: /usr/local/psa/admin/plib/Application/Controller/Action/Helper/ViewRenderer.php:22
Plesk\Application\Controller\Action\Helper\ViewRenderer->render()
4: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Controller/Action/Helper/ViewRenderer.php:972
Zend_Controller_Action_Helper_ViewRenderer->postDispatch()
5: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Controller/Action/HelperBroker.php:277
Zend_Controller_Action_HelperBroker->notifyPostDispatch()
6: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Controller/Action.php:527
Zend_Controller_Action->dispatch(string 'indexAction')
7: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Controller/Dispatcher/Standard.php:308
Zend_Controller_Dispatcher_Standard->dispatch(object of type Zend_Controller_Request_Http, object of type Zend_Controller_Response_Http)
8: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Controller/Front.php:954
Zend_Controller_Front->dispatch()
9: /usr/local/psa/admin/plib/pm/Application.php:87
pm_Application->run()
10: /usr/local/psa/admin/htdocs/modules/softaculous/index.php:11 - Latest version of the Softaculous extension for Plesk is already installed
ionCube loader is missing for all PHP versions installed on the server.
Install ionCube loader for any PHP version by following instructions from the article How to enable ionCube Loader module for PHP shipped with Plesk on Linux?
In case after installing ionCube the issue persists, repair Softaculous:
To repair the Softaculous script installation, you can follow these steps:
1. Log into your server via SSH as the root user
2. Execute the following commands:
# wget http://files.softaculous.com/install.sh
# chmod +x install.sh
# ./install.sh
3. Wait for the installation to finish
After the installation process has finished, open the Softaculous extension via Plesk in order to confirm that the error is not showing.
