How to enable the ionCube Loader module for PHP shipped with Plesk on Linux?
Starting from Plesk Obsidian 18.0.49, the ionCube Loader can be installed for PHP shipped with Plesk as follows:
Note: the example below is shown for PHP 8.2, apply the similar steps for required PHP version.
- Go to Tools & Settings > General Settings > PHP Settings > 8.2, click Manage PECL Packages, and then Install package:
- Specify "ioncube_loader" in the field Package name and click OK:
Go to Tools & Settings > PHP Settings > click on any handler of necessary version (8.2 in the above example) and enable ioncube_loader_lin_X.X.
Connect to a Plesk server using SSH.
Run the command below:
# plesk bin php_handler --extension-install ioncube_loader -id plesk-php81-fpm
Additional information
The IonCube loader is not available for installation in Plesk GUI
For the following steps can be applied to install it manually for PHP 8.1:
Note: ionCube Loader for PHP 8 installation at the server with Plesk had not been tested and Plesk cannot guarantee its stable work.
Connect to the server using SSH.
Download the latest version of the loader:
# cd /root/
# wget https://downloads.ioncube.com/loader_downloads/ioncube_loaders_lin_x86-64.tar.gz -
Unpack it:
# tar -xvf ioncube_loaders_lin_x86-64.tar.gz
Install It:
For Debian and Ubuntu:-
Backup the old loader:
# cp -av /opt/plesk/php/8.1/lib/php/modules/ioncube_loader_lin_8.1.so{,.old}
Install a new one:
# cp -av ioncube/ioncube_loader_lin_8.1.so /opt/plesk/php/8.1/lib/php/modules/ioncube_loader_lin_8.1.so
For RHEL, CentOS and CloudLinux:-
# cp -a /opt/plesk/php/8.1/lib64/php/modules/ioncube_loader_lin_8.1.so{,.old}
Install a new one (confirm file overwriting when asked):
# cp -a ioncube/ioncube_loader_lin_8.1.so /opt/plesk/php/8.1/lib64/php/modules/ioncube_loader_lin_8.1.so
Create ini file:
# touch /opt/plesk/php/8.1/etc/php.d/00-ioncube-loader.ini
Add the following string to ini file:
CONFIG_TEXT: zend_extension=ioncube_loader_lin_8.1.so
Restart Apache Web Server in order to apply the change:
# service apache2 restart
For RHEL-based operating systems:
# service httpd restart
Check the version by executing
php -vcommand:# /opt/plesk/php/8.1/bin/php -v | grep -i ioncube
with the ionCube PHP Loader v12.0.1, Copyright (c) 2002-2022, by ionCube Ltd.
I don't have Manage PECL Packages in PHP settings.
no news for windows
Does not work. Actual loader name includes the version ( i.e. ioncube_loader_lin_8.3.so ) See error below …
Hi Yabz
It is a known issue caused by the bug PPPM-15104 in Plesk, it should be fixed in upcoming Plesk version.
Until it's fixed, use the workaround:
zend_extension=ioncube_loader_lin_X.X.soin the file/opt/plesk/php/X.X/etc/php.d/00-ioncube-loader.ini, where X.X is the affected PHP version.Please sign in to leave a comment.
