kb: bug
Plesk for Linux
ABT: Group A
Unable to add PTR record with subnet mask other than 8, 16, 24 in Domains > example.com > DNS Settings > Add Record. The following error appears:
PLESK_ERROR: Incorrect DNS Record parameter values were specified
This error is caused by limitation of Plesk, which is considered as feature request with ID #PPPM-5231, which is planned to be implemented in future product updates.
Set up 8, 16, 24 subnet mask which meets requirements:
- Log in to Plesk
In Domains > example.com > DNS settings > Add Record specify subnet mask equal to 8, 16 or 24:
修正前の対処方法はありますか?
The article is not really explicative. Which ip adress must we add? (the server?)
and only for mail.domain.com?
