Articles in this section
How to get a traffic usage report for custom period in Plesk?
kb: how-to Plesk for Linux
  • Plesk for Linux
How to get a traffic usage report for a custom period in Plesk?
There is no such tool in Plesk interface that allows filtering traffic usage by date. Suggest such feature in our UserVoice portal.
The top-ranked suggestions are likely to be implemented in next versions of Plesk.
As a workaround, this data can be acquired manually from the database:
  1. Connect to the server using SSH.
  2. Execute the following command to get the list of domains and its traffic usage in MB for the required period:
    Note: change dates to the correct one in the command below.
    # plesk db "select domains.name, round(sum(DomainsTraffic.http_in)/1024/1024,2) as 'HTTP_IN (MB)', round(sum(DomainsTraffic.http_out)/1024/1024,2) as 'HTTP_OUT (MB)', round(sum(DomainsTraffic.ftp_in)/1024/1024,2) as 'FTP_IN (MB)', round(sum(DomainsTraffic.ftp_out)/1024/1024,2) as 'FTP_OUT (MB)', round(sum(DomainsTraffic.smtp_in)/1024/1024,2) as 'SMTP_IN (MB)', round(sum(DomainsTraffic.smtp_out)/1024/1024,2) as 'SMTP_OUT (MB)', round(sum(DomainsTraffic.pop3_imap_in)/1024/1024,2) as 'POP3_IMAP_IN (MB)', round(sum(DomainsTraffic.pop3_imap_out)/1024/1024,2) as 'POP3_IMAP_OUT (MB)' from domains, DomainsTraffic where id=dom_id AND date>='2019-01-01' AND date<='2019-12-26' GROUP BY dom_id;"
  3. The next query will return the list of domains which have no traffic for the required time:
    # plesk db "select name from domains where id not in (select distinct dom_id from DomainsTraffic where date>='2019-01-01' AND date<='2019-12-26')"
  4. The following SQL request will provide traffic usage in MB for the required period and for the specific service plan:
    Note: change dates and service plan name to the correct one in the command below.
    # plesk db "SELECT round(SUM(http_in + ftp_in + smtp_in + pop3_imap_in + http_out + ftp_out + smtp_out + pop3_imap_out)/1024/1024,2) as 'Total traffic usage (MB)' FROM DomainsTraffic as dt LEFT JOIN domains AS d ON d.id = dt.dom_id LEFT JOIN clients AS c ON c.id = d.vendor_id LEFT JOIN Subscriptions AS s ON s.object_type = 'client' AND c.id = s.object_id LEFT JOIN PlansSubscriptions AS ps ON ps.subscription_id = s.id LEFT JOIN Templates AS t ON t.id = ps.plan_id WHERE (c.type = 'reseller') AND (t.name = 'Default') AND (dt.date between '2019-01-01' and '2019-12-26');"
