Articles in this section
Plesk extension development and publication questions
  • What is the official process for publishing an extension in the Plesk Extensions Catalog, including submission procedures, minimum requirements, and review criteria?
  • Are there any automated tests or validation steps required before an extension is approved?
  • What options are available for integrating an extension with the Plesk licensing system to offer it under a subscription or paid model?
  • Where can external developers ask technical questions about Plesk capabilities?
  • How can I implement web server configuration management in a Plesk extension?
Overview
Publishing an extension in the Plesk Extensions Catalog consists of two stages:
  1. Development: you build and test the extension yourself.
  2. Submission: you apply to the Plesk Certification team, who decide whether the extension fits the Catalog strategy and, if so, onboard you as a vendor.
Step 1: Develop and test the extension
  1. Read the Plesk extensions developer guide to understand how extensions are structured.
  2. Set up your development environment with the Plesk Extension SDK (Getting Started).
  3. Build your extension and test it on a Plesk server. You do not need to publish anything to test: you can install the extension from a package file (.zip) by uploading it in Plesk under Extensions > My Extensions > Upload Extension. The Getting Started guide above describes how to build the package.
  4. Check your extension against the technical checklist before you submit it.
Step 2: Prepare and submit your application
Before you apply, make sure your extension meets these requirements:
  • Solid, production-ready code
    • It works on all operating systems and Plesk versions that you claim to support.
    • It has no obvious security issues (for example, no arbitrary commands executed as root).
  • A clear licensing model description (for commercial extensions).
  • Documentation
    • How to install and configure the extension.
    • How the extension works conceptually (used by support and sales teams).
    • Troubleshooting steps for typical issues.
  • A support plan
    • Who handles user issues (your team, as the vendor).
    • What response times (SLAs) users can expect.
Then submit a request through the Plesk Developer Program page and include:
  • A short product description and value proposition.
  • The target audience (Plesk administrators, hosting providers, agencies, and so on).
  • Your monetization idea (subscription, freemium, and so on).
  • The current maturity of the extension (prototype, MVP, or production-ready).
What happens after you submit
The Plesk Certification team reviews your application. If the extension is accepted, they onboard you as a vendor, define the licensing and commercial terms with you, and then the extension is technically integrated into the Catalog. If the team has questions, they will contact you during this stage.
Validation and review criteria
The review criteria are the requirements and the technical checklist listed above. Go through the checklist yourself before applying. The Certification team will tell you about any further checks during the review.
Licensing and paid extensions
If you want to offer your extension under a subscription or paid model, read Monetizing Extensions to see the available options. Describe your intended model in your application. The Certification team defines the final licensing and commercial terms with you during onboarding.
Where to ask questions
  • Questions about the publication process: contact the Plesk Certification team at plesk-extensions@plesk.com. This address is only for existing extension vendors officially supported by Plesk, and for developers who want to publish an extension in the Plesk marketplace by submitting an application.
  • Technical questions about developing extensions: the Certification team does not provide technical assistance to vendors of officially unsupported extensions. Use the developer guide and the Plesk Extension SDK repository on GitHub.
Managing web server configuration from an extension
To manage the web server configuration from a Plesk extension, use the pm_Hook_WebServer hook. It lets your extension add its own configuration to the web server settings that Plesk generates. For details and examples, see Integrate with web server in the extensions guide.
