- Plesk is installed on Almalinux 10
- A Node.js application is deployed on the server. e.g from this repository
- Proxy mode is engaged for the domain, under which application was deployed.
Application doesn't start, the following errors appear in
/var/log/passenger/passenger.log:# [ 66023/T6 age/Cor/SecurityUpdateChecker.h:505 ]: Security update check failed: rate limit hit for your IP, try again later (next check in 24 hours)
App 66547 output:
App 66547 output:
App 66547 output: #
App 66547 output: # Fatal error in , line 0
App 66547 output: # Check failed: 12 == (*__errno_location ()).
App 66547 output: #
App 66547 output: #
App 66547 output: #
App 66547 output: #FailureMessage Object: 0x7ffdc9d9d470
App 66547 output: ----- Native stack trace -----
App 66547 output:
App 66547 output: 1: 0x115bcb1 [/opt/plesk/node/24/bin/node]
App 66547 output: 2: 0x2e8b2e3 V8_Fatal(char const*, ...) [/opt/plesk/node/24/bin/node]
App 66547 output: 3: 0x2e95fc6 v8::base::OS::SetPermissions(void*, unsigned long,
[ E 66023/Tg age/Cor/App/Implementation.cpp:218 ]: Could not spawn process for application /var/www/vhosts/example.com/passenger-nodejs-connect: -
The following is being logged under
/var/log/messages:# kernel: traps: MainThread[66547] trap int3 ip:2e9640c sp:7ffdc9d9d440 error:0 in node[2a9640c,f3e000+27e4000]
Sep 11 08:52:30 10-69-43-244 systemd-coredump[66585]: Process 66547 (MainThread) of user 10000 terminated abnormally with signal 5/TRAP, processing...
systemd[1]: Started systemd-coredump@3-66585-0.service - Process Core Dump (PID 66585/UID 0).
systemd-coredump[66586]: Process 66547 (MainThread) of user 10000 dumped core.#012#012Stack trace of thread 66547:#012#0 0x0000000002e9640c n/a (n/a + 0x0)#012#1 0x0000000002e8b2f4 n/a (n/a + 0x0)#012#2 0x0000000002e95fc6 n/a (n/a + 0x0)#012#3 0x00000000015a5c2c n/a (n/a + 0x0)#012#4 0x000000000164b65f n/a (n/a + 0x0)#012#5 0x000000000157c7de n/a (n/a + 0x0)#012#6 0x0000000001b56043 n/a (n/a + 0x0)#012#7 0x00000000013d02d6 n/a (n/a + 0x0)#012#8 0x0000000000f9947f n/a (n/a + 0x0)#012#9 0x00000000011193d9 n/a (n/a + 0x0)#012#10 0x000000000105a846 n/a (n/a + 0x0)#012#11 0x00007f31edf77348 __libc_start_call_main (libc.so.6 + 0x2a348)#012#12 0x00007f31edf7740b __libc_start_main@@GLIBC_2.34 (libc.so.6 + 0x2a40b)#012#13 0x0000000000f908be n/a (n/a + 0x0)#012ELF object binary architecture: AMD x86-64
systemd[1]: systemd-coredump@3-66585-0.service: Deactivated successfully.
Product defect with ID EXTPLESK-9287 which will be fixed in the future Plesk updates. A directive "MemoryDenyWriteExecute=yes" in Apache service configuration was introduced in AlmaLinux 10, which forbids any memory mappings that are both writable and executable in processes started by Apache.
Until a fix is released, apply the following workaround.
- Connect to the Plesk server via SSH.
Disable
MemoryDenyWriteExecuteApache directive by creating a drop-in under/usr/lib/systemd/system/httpd.service.d/nodejs.confwith the following command:# echo -e "[Service]\nMemoryDenyWriteExecute=no" > /usr/lib/systemd/system/httpd.service.d/nodejs.conf
Reload services:
# systemctl daemon-reload
# systemctl restart httpd
