Articles in this section
Plesk Sitejet domain fail to publish with permissions error for .well-known directory: filemng: Error occurred during /bin/rm command.
Plesk for Linux kb: technical ext: sitejet
  • Publishing a website from Siejet removes .well-known folder or fails with below error if the folder permissions are not by default:
    Publication failed. Please try again
    filemng failed: rm: cannot remove '/var/www/vhosts/example.com/httpdocs/.well-known/pgp-key.txt': Permission denied
    rm: cannot remove '/var/www/vhosts/example.com/httpdocs/.well-known/security.txt': Permission denied
  • Extension Native security.txt compliance is installed and configured on the server.
This is the Plesk Sitejet Builder extension bug EXTPLESK-9140, which will be fixed in future extension updates.
In the meantime as a workaround:
  1. Connect to a Plesk server via SSH.
  2. Temporarily move the .well-known directory out:
    # mv /var/www/vhosts/example.com/httpdocs/.well-known /var/www/vhosts/example.com/
  3. Publish the changes from Sitejet
  4. Move .well-known back to the domain directory root:
    # mv /var/www/vhosts/example.com/.well-known /var/www/vhosts/example.com/httpdocs/
