Plesk for Windows
Plesk for Linux
kb: technical
Sitejet Builder cannot be opened for a domain in Plesk. The following error is displayed in the Plesk UI:
PLESK_ERROR: Error: Could not connect to Website Builder API
- The same error is also recorded in
/var/log/plesk/panel.log.
Plesk cannot reach the Sitejet API endpoints on port 443. This is required for Sitejet Builder to function. The affected hostnames are:
- api.sitehub.io
- api.sitejet.io
- Connect to the server via SSH.
Check whether outbound traffic on port 443 is being blocked:
On servers using
firewalld:# firewall-cmd --list-all
On servers using
iptables:# iptables -L OUTPUT -n -v
Note: If the server is a VPS or dedicated server with a hosting provider, check whether outbound traffic restrictions are applied at the hypervisor or network level, as these would not be visible in the server's own firewall rules.
- Allow outbound HTTPS traffic to the Sitejet endpoints if it is being blocked. The firewall rules can be managed with the Plesk Firewall extension.
