Articles in this section
Plesk interface shows: cURL error (77): Error in cURL request: Problem with the SSL CA cert (path? access rights?
Plesk for Linux kb: technical
  • Plesk for Linux
  • On Plesk Interface the Home - What's New box may show the following error when trying to open it:
    PLESK_ERROR: error setting certificate verify locations: Error in cURL request: Problem with the SSL CA cert (path? access rights?
PHP cURL uses an outdated set of root certificates to verify server certificates.
  2. Download the CA certificate store from the official cURL website and move it to the directory /etc/ssl/certs/:
    # wget https://curl.haxx.se/ca/cacert.pem && mv cacert.pem /etc/ssl/certs/
  3. Add the following line into the end of the file /usr/local/psa/admin/conf/php.ini:
    CONFIG_TEXT: curl.cainfo="/etc/ssl/certs/cacert.pem"
  4. Restart the Plesk engine service via the following command:
    # systemctl restart sw-engine
    Once this is done, you should be able to see the What's New box without issues
Additional information
Website on Plesk shows: cURL error (77): Problem with the SSL CA cert
