- Plesk Obsidian is updated to version 18.0.80 or later.
- WHMCS is connected to the Plesk server.
When performing an action from WHMCS (for example, syncing accounts, or suspending/unsuspending a service), the following error appears:
CONFIG_TEXT: Module Command Error
Error code: 1014. Error message: Parser error: Request is invalid. Error in line 2: Element 'domain': This element is not expected. Expected is one of ( request-settings, server, customer, webspace, subdomain, dns, db_server, mail, certificate, site-alias ).
Plesk 18.0.80 began validating all XML API requests against the API schema. Requests that used a legacy or unversioned protocol version were not validated at all before that. Older versions of the WHMCS Plesk module send suspend and unsuspend requests in a format that has not been valid since protocol version 1.6.3.0.
This was a bug in the WHMCS Plesk module and is fixed in WHMCS 9.0.8 (tracked as WHMCS-27532 and WHMCS-27812 in the WHMCS Change log).
In order to resolve this, make sure WHMCS is updated to version 9.0.8 or later.
If WHMCS cannot be updated right away, the workaround is to suspend and activate subscriptions in Plesk directly:
- Log into Plesk (not through WHMCS).
- Go to Websites & Domains.
- Use the subscription's Suspend / Activate action to suspend or unsuspend the service manually.
- Repeat this manually for each affected subscription until WHMCS is updated.
Unfortunately still getting error:
One man helped on WHMCS forum:
Fix Error:
/modules/servers/plesk/templates/api/1.0.0.0/webspace_set_status.tpl
<!-- Copyright 1999-2016. Parallels IP Holdings GmbH. --> <webspace> <set> <filter> <name><?php echo $domain; ?></name> </filter> <values> <gen_setup> <status><?php echo $status; ?></status> </gen_setup> </values> </set> </webspace>There are other features that don't work, such as password changing. I resolved this by copying all the files from the `/modules/servers/plesk/templates/api/1.0.0.0` folder from WHMCS 9.0.8.
