Articles in this section
Website on Plesk shows: cURL error (77): Problem with the SSL CA cert
kb: technical Plesk Obsidian for Linux Plesk Obsidian for Windows
  • Plesk for Linux
  • Plesk for Windows
  • A website or PHP scripts show the following error:
    CONFIG_TEXT: cURL error (77): Problem with the SSL CA cert (path access rights)cURL error (77): Problem with the SSL CA cert (path access rights)
    CONFIG_TEXT: Error : "error setting certificate verify locations: CAfile: C:\Program Files (x86)\Plesk\Additional\PHPSettings\cacert.pem CApath: none"
    CONFIG_TEXT: cURL error 77: error setting certificate verify locations: CAfile: /etc/ssl/certs/cacert.pem CApath: /etc/ssl/certs
  • On Plesk for Windows the Extensions menu may show the following error when trying to open it:
    PLESK_ERROR: error setting certificate verify locations: CAfile: C:\Program Files (x86)\Plesk\admin\conf\cacert.pem CApath: none
PHP cURL uses an outdated set of root certificates to verify server certificates.
Solution 1 - Using Plesk GUI
  1. Log in to Plesk.
  2. Install Panel.ini Editor extension: Extensions > Server Tools section > Panel.ini Editor.
  3. Go to Extensions > My Extensions > Panel.ini Editor (Go To Extension) > Editor.
  4. Add records below to the editor and Save changes:
    CONFIG_TEXT: [php]
    curlCertificatesUrl="http://curl.haxx.se/ca/cacert.pem"
  5. Wait until Daily task is executed (It is executed once a day).
  6. Go to Domains > example.com > PHP Settings and add the line below into Additional configuration directives. Replace path to cacert.pem with your own path.
    CONFIG_TEXT: curl.cainfo="C:\Program Files (x86)\Plesk\Additional\PHPSettings\cacert.pem"
    If it is required to apply the changes for all the domains using a particular PHP version go to Tools & Settings > PHP Settings> %PHP_version%, click on php.ini tab and add the following line at the end of file:
    CONFIG_TEXT: curl.cainfo="/etc/ssl/certs/cacert.pem"
Solution 2 for Windows
  1. Log in to the server via RDP.
  2. Download the cacert.pem file from the main curl website http://curl.haxx.se/ca/cacert.pem.
  3. Open %plesk_dir%admin\conf\panel.ini file (create it from panel.ini.sample if it doesn't exist)
    Note: %plesk_dir% by default is C:\Program Files (x86)\Plesk\
  4. Add below directive to panel.ini.
    CONFIG_TEXT: [php]
  5. Place downloaded cacert.pem to %plesk_dir%Additional\PHPSettings\ directory.
  6. Wait until Daily task is executed (It is executed once a day).
Solution 2 for Linux
  2. Download the CA certificate store from the official cURL website and move it to the directory /etc/ssl/certs/:
    # wget https://curl.haxx.se/ca/cacert.pem && mv cacert.pem /etc/ssl/certs/
  3. Log into Plesk.
  4. Go to Tools & Settings > PHP Settings > %PHP version% > php.ini.
  5. Add the following line into the end of the file:
  6. Click OK to save the file
