Articles in this section
Is Plesk affected by CVE-2026-23918? (Double Free and possible RCE in Apache http2 module)
Plesk for Linux kb: technical Plesk Obsidian for Linux
Is the Plesk affected by CVE-2026-23918?
The issue affects Apache 2.4.66 and its http2 module specifically.
Plesk uses Apache from OS repositories, so if the OS distribution provides Apache 2.4.66 - it is affected by the issue.
If Apache 2.4.66 is installed - update Apache to the version 2.4.67 (manually via CLI, or via Tools & Settings > System Updates menu).
Apache version can be checked OS package manager, or via Tools & Settings > Server Components menu.
How to check Apache version and install updates via CLI:
  2. Check currently installed Apache version:
    • On Ubuntu/Debian:
    # apt info apache2
    Package: apache2
    Version: 2.4.52-1ubuntu4.19
    Priority: optional
    Section: web
    Origin: Ubuntu
    Maintainer: Ubuntu Developers ubuntu-devel-discuss@lists.ubuntu.com
    Original-Maintainer: Debian Apache Maintainers debian-apache@lists.debian.org
    • On RHEL-like (RHEL, CentOS, AlmaLinux, Rocky Linux, CloudLinux):
    # yum info httpd
    Installed Packages
    Version : 2.4.62
    Release : 7.el9_7.3
    Architecture : x86_64
    Source : httpd-2.4.62-7.el9_7.3.src.rpm
    Repository : @System
  3. Check for available updates and :
    • On Ubuntu/Debian:
    # apt update && apt list --upgradable
    Note: On Ubuntu/Debian updates are intsalled with apt upgrade command
    # yum update
Workaround - Disable HTTP/2 (on Apache-only environment, if updates cannot be installed)
  1. Log into Plesk
  2. Navigate to Tools & Settings > Apache & Nginx Settings
  3. Disable the following modules: http2, proxy_http2
  4. Connect to the server via SSH
  5. Check the status of Nginx:
# plesk sbin nginxmng --status
If the command provides Disabled, then Apache-only setup is used.
  1. Verify if the example.com (some hosted domain or Plesk hostname) uses HTTP/2 or HTTP/1.1:
# curl -IvLk https://example.com
Output like below should be provided when HTTP/1.1 is used:
*   Trying 203.0.113.2:80...
* Connected to example.com (203.0.113.2) port 80 (#0)
> HEAD / HTTP/1.1
> Host: example.com
> User-Agent: curl/7.81.0
> Accept: */*
* Mark bundle as not supporting multiuse
< HTTP/1.1 301 Moved Permanently
< Date: Wed, 06 May 2026 11:23:49 GMT
< Server: Apache
Server: Apache
< Location: https://example.com/
< Content-Type: text/html; charset=iso-8859-1
* Connection #0 to host example.com left intact
Additional information
1 comment
Date Votes
  • Apache 2.4.66 users on Plesk should take note—this CVE directly impacts the HTTP/2 module. Since Plesk relies on the OS-provided Apache packages, affected servers will need to upgrade to 2.4.67 right away. Check your current version through the Server Components panel or your package manager, then apply the update either manually via CLI or through the System Updates interface in Plesk. Don't delay on this one if you're running 2.4.66.
    2
