- The server is running on CloudLinux with CageFS enabled
- NodeJS Toolkit extension is installed in Plesk
- The following error is displayed when accessing chrooted shell of a system user:
# -chrootsh: nodenv: command not found
The error is a known bug identified as #EXTNODEJS-328, which will be addressed in future updates.
One can monitor the Plesk Change Log for when the bug is resolved.
The /etc/profile.d/nodenv.sh file which is a part of the Node.js toolkit executes the nodenv command, however, there is no nodenv binary in the CageFS template at /usr/share/cagefs-skeleton/.
In order to resolve the issue, the following workaround can be applied:
2. Create the file /etc/cagefs/conf.d/nodenv.cfg:
# touch /etc/cagefs/conf.d/nodenv.cfg
3. Edit the file with your preferred editor and add the following directives within it:
PLESK_INFO: [nodenv]
comment=nodenv by Plesk
paths=/usr/bin/nodenv, /usr/libexec/nodenv, /opt/plesk/node/.
4. Update CageFS with the following command:
# cagefsctl --force-update
