Articles in this section
A .NET application does not work in Plesk on CloudLinux: dotnet: not found
Plesk for Linux kb: technical
  • Plesk for Linux
  • Plesk is installed on CloudLinux OS.
  • When opening a .NET-based website in a web-browser, it fails to load.
  • The following error message appears in /var/log/passenger/passenger.log:
    CONFIG_TEXT: App 53089 output: /bin/sh: line 0: exec: dotnet: not found
    Could not spawn process for application /var/www/vhosts/example.com/httpdocs: The application process exited prematurely.
.NET software is being blocked by CageFS (part of CloudLinux Manager extension for Plesk).
Solution I: Add dotnet packages into CageFS using the steps from this CloudLinux KB article:
To list all dotnetpackages, run the command:
# yum list installed | grep dotnet*
Solution II: Disable CageFS for the subscription system user at Plesk > CloudLinux Manager > Users tab.
