Plesk Repair kit shows this error
pm_Settings::set. Value length 5000 expected, XYZ received
The panel log shows the same errors
# grep -r "Invalid usage of pm_Settings::set" /var/log/plesk/panel.log
ERR [extension/repair-kit] Invalid usage of pm_Settings::set. Value length 5000 expected, 6945 received.
ERR [extension/repair-kit] Invalid usage of pm_Settings::set. Value length 5000 expected, 6636 received.
This is a Repair Kit product issue with ID EXTPLESK-2460. This article will be updated when the fix is released.
The error doesn't affect the repair process. It can be safely ignored.
