kb: bug
Plesk for Linux
kb: technical
- Generating new signing keys and selecting them via the Active DKIM Selector in Plesk > Domains > example.com > Mail Settings is possible
- After deactivating and reactivating DKIM spam protection in Plesk > Domains > example.com > Mail Settings, a new DKIM key is not visible in Plesk > Domains > example.com > Mail Settings > How to configure external DNS
- The necessary keys are also not present in
/etc/domainkeys/
The issue was confirmed as a bug with ID #PPPM-14160 DKIM key not visible and was resolved permanently in Plesk Obsidian version 18.0.57.
Update Plesk Obsidian to version 18.0.57 by using the information in this article:
How to update Plesk Obsidian to the latest build?
Afterwards, go to Plesk > Domains > example.com > Mail Settings , uncheck the Use DKIM spam protection system to sign outgoing box, save the changes, check it and save the changes once again.
That should make the DKIM appear in Plesk > Domains > example.com > Mail Settings > How to configure external DNS.
Alternatively, if turning DKIM off and on again does not resolve the issue, you can manually create the keys using the following instructions:
# mkdir /etc/domainkeys/example.com
# cd /root
# openssl genrsa -out private.key 1024
# mv private.key /etc/domainkeys/example.com/default
# chmod 440 /etc/domainkeys/example.com/default
# chown root:pouser /etc/domainkeys/example.com/default
# cd /etc/domainkeys/example.com/
# openssl rsa -in default -pubout -out public.key
# openssl rsa -in /etc/domainkeys/example.com/default -pubout
The problem now is present in Plesk for Windows after updating to Plesk Obsidian 18.0.77
We need you to check it.
