Articles in this section
Grafana does not work: login.OAuthLogin(missing saved state)
Plesk for Linux kb: technical
  • Plesk for Linux
  • Grafana graphs are not shown:
CONFIG_TEXT: 203.113.0.2 redirected you too many times
OR
CONFIG_TEXT: login.OAuthLogin(missing saved state)
  • Plesk is installed on AlmaLinux 9 server
  • The following errors occur in Grafana log /var/log/grafana/grafana.log
CONFIG_TEXT: logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2023-07-13T10:38:54.40646435+02:00 level=error msg="Request Completed" method=GET path=/login/generic_oauth status=500 remote_addr=127.0.0.1 time_ms=0 duration=490.443µs size=1388 referer="https://203.113.0.2:8443/modules/monitoring/index.php/index/main?context=extNavButton_monitoring_1" traceID=00000000000000000000000000000000
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2023-07-13T10:38:54.527613555+02:00 level=error msg="Request Completed" method=GET path=/login/generic_oauth status=500 remote_addr=127.0.0.1 time_ms=0 duration=743.878µs size=1388 referer="https://203.113.0.2:8443/modules/monitoring/index.php/index/main?context=extNavButton_monitoring_1" traceID=00000000000000000000000000000000
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2023-07-13T10:49:29.26752975+02:00 level=error msg="user already exists"
logger=context traceID=00000000000000000000000000000000 userId=0 orgId=0 uname= t=2023-07-13T10:49:30.229244061+02:00 level=error msg="user already exists"
  • The TOO_MANY_REDIRECTS error appears in the browser when the Grafana application is opened from Plesk > Extensions > Graphana > Open Application
Plesk bug #EXTPLESK-4838 - Unsupported version of Grafana installed on AlmaLinux 9
As a workaround, perform the following steps:
  1. Log in to the server via SSH.
  2. Open /etc/yum.repos.d/almalinux-appstream.repo with any text editor and add the exclude=grafana line under the [appstream] block:
    CONFIG_TEXT: [appstream]
    exclude=grafana
  3. Remove the Grafana Extension:
    # plesk bin extension -u grafana
    The extension was successfully removed.
  4. Remove the grafana package:
    # yum remove grafana -y
    Dependencies resolved.
    Complete!
  5. Install the Grafana Extension:
    # plesk bin extension -i grafana
