Articles in this section
Plesk PHP handler is missing from Admin and Domains PHP Settings after installation
kb: technical
  • After installing a Plesk PHP handler this is not listed in Tools & Settings > PHP Settings or in Domain > example.com > PHP Settings > PHP version.
  • The following errors are found at /var/log/plesk/panel.log during the Plesk PHP component installation:
    CONFIG_TEXT: [Warning] removing handler (plesk-php80-cgi) due to errors in getting php version : can not get version from /opt/plesk/php/8.0/bin/php-cgi [Warning] removing handler (plesk-php80-fastcgi) due to errors in getting php version : can not get version from /opt/plesk/php/8.0/bin/php-cgi
    [Warning] removing handler `8.0.28' (plesk-php80-fpm) due to errors in getting php version : can not get version from /opt/plesk/php/8.0/bin/php
  • An attempt to query the PHP version manually also fails:
    # /opt/plesk/php/8.0/bin/php -V
    /opt/plesk/php/8.0/bin/php: symbol lookup error: /opt/plesk/php/8.0/bin/php: undefined symbol: history_list
  • The package libedit2 is found to be outdated with a more recent candidate:
    # apt-cache policy libedit2
    libedit2:
    Installed: 3.1-20150325-1ubuntu2
    Candidate: 3.1-20170329-1
Outdated libedit2 package.
  2. Update the package libedit2 library using the next command:
    # apt-get install libedit2
  3. Log into Plesk
  4. Remove and install again the affected PHP handler handler following the steps from this article
