Plesk for Linux
kb: technical
ext: git
The Domains > example.com > Git menu cannot be opened with error:
PLESK_ERROR: 500 PleskUtilException
filemng failed: base64: /var/www/vhosts/example.com/.ssh/id_rsa: Permission denied filemng: Error occurred during /usr/bin/base64 command.
Incorrect ownership to the files/folders inside /var/www/vhosts/example.com/.ssh/ directory.
- Connect to the server via SSH
Determine the system user of the subscription (replace
example.comwith the actual name of subscription):# grep example.com /etc/passwd
johndoe:x:10000:1003::/var/www/vhosts/example.com/:/bin/false -
Execute the command below to set proper ownership (replace the
johndoeandexample.comwith actual system user and subscription names):# chown -R johndoe:psacln /var/www/vhosts/example.com/.ssh/
