Articles in this section
360 Monitoring agent installation fails: libpython3-dev (= 3.8.2-0ubuntu2) but it is not going to be installed
kb: bug kb: fixed Plesk 360 360 monitoring
  • 360 Monitoring agent installation fails with the error:
    CONFIG_TEXT: The following packages have unmet dependencies:
    python3-dev : Depends: libpython3-dev (= 3.8.2-0ubuntu2) but it is not going to be installed
    Depends: python3.8-dev (>= 3.8.2-1~) but it is not going to be installed
    E: Unable to correct problems, you have held broken packages.
  • The server is running under Ubuntu 20.04
Product issue:
  • #EXTPLESK-3311 "agent360 installation no longer fails on Ubuntu 20 because of the Ubuntu bug."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
  2. Downgrade the necessary packages:
    # sudo apt install libc6=2.31-0ubuntu9.2 libc-bin=2.31-0ubuntu9.2 libc6-i386=2.31-0ubuntu9.2
  3. Try to install the agent once again
