Plesk 360
Platform 360
360 Monitoring
- 360 Monitoring installation fails on CentOS/AlmaLinux 9:
CONFIG_TEXT: Installer exited with error code 0. See /var/log/agent360-install.log for details.
- Inside the file /var/log/agent360-install.log the following error can be found:
CONFIG_TEXT: Error: Unable to find a match: python36-devel
The issue is caused by bug in 360 Monitoring installation script with ID CPCLOUD-1526. It will be fixed in future product udpates.
As a workaround install 360 Monitoring as follows:
- Download installation script first:
# wget -q -N monitoring.platform360.io/agent360.sh
- Patch the script by executing below command::
# sed -i 's/python36/python3/g' agent360.sh && sed -i 's/pip3.6/pip3/g' agent360.sh
- Restart agent installation using patched agent360.sh script:
# bash agent360.sh <your unique UUID here>
