kb: technical
The CLI PHP Composer extension command below fails with an error:
# plesk ext composer --application -list
Call to undefined function PleskExt\Composer\Cli\create_function()
Plesk PHP Composer extension bug with ID #EXTPHPCOMP-249 which will be fixed in future extension updates.
Workaround
Until the bug is fixed as a workaround:
Find the applications list at Domains > example.com > PHP Composer
If we need to use plesk ext composer command, that's coz the composer extension still has issues to find composer.json in subdirectories of websites.
So thanks for your article but using Plesk composer extension UI does not help at all
