- The following error is displayed when trying to issue a Digicert certificate for a domain:
PLESK_INFO: Issuing the certificate. The order is taking too long to process. It seems that something went wrong. Please contact your administrator or Plesk support.
- Errors like below can be found in
/var/log/panel.log(with enabled Plesk debug mode):
PLESK_INFO: [stream:protected] => Digicert\Api\Stream Object
( [body:Digicert\Api\Stream:private] =>
{"order_id":"123456789","order_status":"pending","order_name_scope":"fqdn","order_dcv_method":"http-token","dns_name_validations":[{"status":"approved","dns_names":["example.com"],"base_domain":"example.com"},{"status":"approved","dns_names":["www.example.com"],"base_domain":"example.com"}]}
[2022-11-24 13:13:34.137] 123381:637f5fe96dc8d ERR [extension/sslit] Error happened while certificate processing : The order is taking too long to process. It seems that something went wrong. Please contact your administrator or Plesk support.
[2022-11-24 13:13:34.138] 123381:637f5fe96dc8d INFO [extension/sslit] Check notifications which already sent in interval since 1669205614 to 1669292014.
DNS CAA record is absent for the domain example.com
Add the digicert.com CAA record for the example.com domain: How to add a CAA DNS record on a domain in Plesk?
An example of CAA records may be found in the following Digicert documentation article: https://docs.digicert.com/en/certcentral/manage-certificates/dns-caa-resource-record-check.html
