kb: how-to
Plesk for Linux
ext: wptk
- How does Smart Update work when Autoupdate is enabled for WordPress in WP Toolkit?
- Will my WordPress website still be updated automatically if I use Smart Updates?
- What happens if Smart Update finds a problem with an update?
Autoupdate and Smart Update are two separate features that work as a team:
- Autoupdate decides what gets updated automatically (WordPress itself, plugins, and themes). It must stay enabled. Without it, the updates are not applied to your website.
- Smart Update acts as a safety check. Before an update reaches your live website, it tests the update on a private copy of the site first.
If the test goes well, your live website is updated. If the test finds a problem, your live website is left untouched and you receive an email.
Example setup
The steps below describe what happens when Smart Updates is switched on for a website and the Autoupdate settings in WP Toolkit look like this:
- Update WordPress automatically: Yes
- Update plugins automatically: Forced
- Update themes automatically: Forced
What happens step by step
Plesk checks for updates on a schedule. A scheduled task (a job that runs automatically at set times) looks for new updates for your WordPress websites. This is the same schedule WP Toolkit uses for regular WordPress updates. (Technical detail: the task runs the WP Toolkit script
instances-auto-update.php, which starts the Smart Update process.) - Smart Update makes a copy of your website. If an update is available, WP Toolkit creates a temporary copy (a "clone") of your site. Your real website is not touched and visitors notice nothing.
- The update is installed on the copy. Only the copy is updated.
- The copy is checked. WP Toolkit analyzes the updated copy to see whether the update changed or broke anything.
Your live website is updated, or left alone, depending on the result. (Technical detail: this decision controls whether the WordPress cron task
wp_version_checkis run. That task is what actually applies the updates to your live website.)-
No issues found: The
wp_version_checktask runs, and WordPress updates your live website automatically. -
At least one issue found: The
wp_version_checktask does not run, so the update is not applied to your live website. Instead, you receive an email with the test result.
What to do if you receive an email about a problem
The email contains a link to a report. The report shows "before" and "after" screenshots of your website, so you can see what the update would have changed. Based on that comparison, you can decide how to proceed, for example, whether to go ahead with the update anyway or to wait.
How to find out when the updates run
- Log in to Plesk.
- Go to Tools & Settings > Scheduled Tasks (Cron jobs).
- Look for the task
/opt/psa/admin/plib/modules/wp-toolkit/scripts/instances-auto-update.php. The schedule listed there shows when the update checks run.
More information
For all available update settings, see Updating WordPress Installations | Plesk Obsidian documentation.
