kb: technical
ext: le
ABT: Group B
Unable to renew/issue Let's Encrypt certificate:
PLESK_ERROR: CAA record for example.com prevents issuance
Checking CAA record for example.com returns the following:
# dig caa example.com +short
0 issue "example.com"
The DNS record for the certification authority does not permit the issuance of a Let's Encrypt certificate.
- Log into Plesk.
- Open Domains > example.com > DNS Settings > select CAA record and delete it using Remove button.
- Press Update to save changes:
