Articles in this section
MySQL Process List in Plesk does not work: Request failed with status code 500
kb: bug Plesk Obsidian for Linux ABT: Group B Ideal
  • Plesk Obsidian for Linux
  • On a Plesk Obsidian for Linux server, the following error is shown in the menu Tools & Settings > Assistance and Troubleshooting > MySQL Process list (Beta):
    CONFIG_TEXT: Request failed with status code 500
    Click Install
  • The following error is found in the file /var/log/plesk/panel.log with Plesk debug mode enabled:
    CONFIG_TEXT: ERR [panel] SQLSTATE[HY000] [1045] Access denied for user 'admin'@'localhost' (using password: YES):
  • The value in the column admin_password of the table DatabaseServers from the Plesk database doesn't contain a valid value (8 asterisks):
    Note: If the value of the admin_password is valid, the following command will return 1
    # plesk db -Ne "select COUNT(admin_password) from DatabaseServers where id = 1 and admin_password = '********' "
Issue is caused by bug with ID PPPM-11086, which is planned to be fixed in product future updates.
Apply the following workaround if the server was affected by this bug:
Workaround
  1. Connect to the server via SSH
  2. Back up the Plesk database:
    # plesk db dump psa > psa.backup.sql
  3. Configure the value of the  admin_password for the local MySQL server with 8 asterisks:
    # plesk db "update DatabaseServers set admin_password='********' where id = 1"
1 comment
Date Votes
