- Plesk for Windows
It is not possible to install WordPress via WP Toolkit with the error:
PLESK_ERROR: Specified column "guid" is not in the row
The same error can be found in the file
/var/log/plesk/panel.log:CONFIG_TEXT: ERR [panel] Zend_Db_Table_Row_Exception: Specified column "guid" is not in the row
When updating or reinstalling an existing WordPress instance with WP Toolkit, a similar error to the following is written to
/var/log/plesk/panel.log:CONFIG_TEXT: DEBUG [extension/wp-toolkit] Exception: Database migration has failed. Log of phinx:
Phinx by CakePHP - https://phinx.org. 0.11.1
using config file ./usr/local/psa/admin/plib/modules/wp-toolkit/library/Db/phinx.php
using config parser PHP
using migration paths
- /usr/local/psa/admin/plib/modules/wp-toolkit/library/Db/Migrations
warning no environment specified, defaulting to: production
using adapter sqlite
using database /usr/local/psa/var/modules/wp-toolkit/wp-toolkit.sqlite3
== 20190517060827 ChangeColumnsDefinitionToCorrect: migrating
PDOException: SQLSTATE[HY000]: General error: 11 database disk image is malformed in /usr/local/psa/admin/plib/modules/wp-toolkit/vendor/robmorgan/phinx/src/Phinx/Db/Adapter/PdoAdapter.php:168
Corrupted WP Toolkit SQLite database.
Add missing column to WP Toolkit database:
Connect to the server via SSH
Create a backup of the SQLite3 database:
# cp /usr/local/psa/var/modules/wp-toolkit/wp-toolkit.sqlite3 /usr/local/psa/var/modules/wp-toolkit/wp-toolkit.sqlite3.bak
Access the SQLite3 database:
# sqlite3 /usr/local/psa/var/modules/wp-toolkit/wp-toolkit.sqlite3
Update the table
Instances# sqlite> ALTER TABLE Instances ADD COLUMN
guidVARCHAR(36) NULL; -
Disconnect from the SQLite database:
# sqlite> .q
Connect to the server via RDP
Create a backup of the original database at
%plesk_dir%\var\modules\wp\-toolkit\wp-toolkit.sqlite3 -
Open a command-line window and access the database using the SQLite3 utility with the following command:
C:\> "%plesk_bin%\sqlite3" "%plesk_dir%\var\modules\wp-toolkit\wp-toolkit.sqlite3"
Update the table
Instances:C:\> sqlite> ALTER TABLE Instances ADD COLUMN `guid` VARCHAR(36) NULL;
C:\> sqlite> .q
Note: In case the resolution above does not fix the issue remove the extension WP Toolkit and install it again.
