Plesk for Linux
kb: technical
How to enable CGroups for advanced monitoring in Plesk for Linux?
Install CGroups on the Plesk server (Compatible operating systems)
- Log into Plesk
Go to Monitoring > Settings > Subscription monitoring
Tick the checkbox Enable Resource Controller (Cgroups)
Press OK
Alternatively, you may enable the integration via the command-line interface with the following command:
# plesk sbin resctrl --enable
Note: Enabling the integration will allow checking the resource usage under any subscription.
