- Plesk for Windows
It is not possible to create a Presence Builder site, the
Presence Buildericon is missing. - Many elements are missing from Tools & Settings
There is no
Presence Buildericon, even for a domain that has a quickPresence Builder Edit Websitebutton. -
There is a customizations.conf file that disables extension or component, for example, the Presence Builder section:
# grep sitebuilder /usr/local/psa/admin/conf/customizations.conf
{"ini":{"aps":{"serverAppsPromoEnabled":false},"promos":{"enabled":false,"cloudFlare":{"active":true},"commTouch":{"active":true},"googleIntegration":{"active":true},"helpDesk":{"active":true},"mobile":{"active":true},"sitebuilderTrial":{"active":true},"techDomain":{"active":true}},"google":{"tools":{"enabled":false}},"sitebuilder":{"enabled":false},"marketplace":
Cannot install an extension, for example, Panel Migrator:
PLESK_ERR: ERROR: Failed to install the extension 'Plesk Migrator' (package: panel-migrator):
The extension panel-migrator is not allowed for installation.
Components is disabled in customizations.conf. For example, the file contains "sitebuilder":{"enabled":false} directive. This means the Presence Builder button is disabled for domains.
Edit the file
/usr/local/psa/admin/conf/customizations.confand add or update the following string:CONFIG_TEXT: "sitebuilder":{"enabled":true}
Note: In Plesk on Windows the path to the file is
%plesk_dir%\admin\conf\customizations.conf.
Additional Information
In case this article helps, then note that such restrictions was applied from the license key used on the server. In order to clarify the purpose of such restrictions, get in contact with your service provider.
