Articles in this section
How to enable or disable web statistics for a domain in Plesk?
Plesk for Windows kb: how-to Plesk for Linux
  • Plesk for Linux
  • Plesk for Windows
  • How to enable or disable web statistics for a domain in Plesk?
  • Can I enable or disable web statistics for a website in Plesk?
Note: There are three web statistics components that come along with Plesk and can be installed via Plesk Installer:
  • AWStats (Deprecated, Starting with Plesk Obsidian 18.0.77, GoAccess is the default and recommended web statistics tool)
  • GoAccess (Linux only)
  • Webalizer
Enabling or disabling web statistics via Plesk
  1. Log in to Plesk.
  2. Go to Domains > example.com > Hosting.
  3. Set Web statistics in accordance with your needs.
Enabling or disabling web statistics via a command-line interface
  1. Connect to the Plesk server via  SSH (Linux) or RDP (Windows Server) .
  2. Execute the following command:
    CONFIG_TEXT: plesk bin domain --update example.com -webstat <option>
    where available options are:
    • none
    • awstats
    • goaccess
    • webalizer
Note: GoAccess is not available for Windows.
(Linux) Enabling or disabling web statistics for all domains
  1. Connect to the Plesk server via SSH.
  2. Generate a list of all subscriptions:
    CONFIG_TEXT: plesk bin subscription --list > /root/subscriptions.txt
  3. (Optional) Open the file /root/subscriptions.txt in a text editor and remove subscriptions which should not be changed.
  4. Execute the following command:
    CONFIG_TEXT: cat /root/subscriptions.txt | while read i; do plesk bin domain --update $i -webstat <option> ; done
    • none
    • awstats
    • goaccess
    • webalizer
(Windows) Enabling or disabling web statistics for all domains
  1. Connect to the Plesk server via RDP.
    PS plesk bin subscription --list > /root/subscriptions.txt
    PS more C:\subscriptions.txt | % { if ($_) { plesk bin domain --update $_ -webstat <option> } }
    • none
    • awstats
    • webalizer
Additional Information
Statistics and Logs | Plesk Obsidian documentation
Viewing Statistics | Plesk Obsidian documentation
View Site Visit Statistics | Plesk Obsidian documentation
1 comment
Date Votes
  • You couldn't provide any documentation for this new replacement for stats?
