Articles in this section
How to verify that SSL for IMAP/POP3/SMTP works and a proper SSL certificate is in use
kb: how-to Plesk for Linux ABT: Group B
  • Plesk for Linux
How to verify that SSL for IMAP/POP3/SMTP works and a proper certificate is installed?
Using online checkers
Check SSL using online tools:
Using a Linux server
Any Linux server can be used for these tests. If you do not have a Linux server, use the online checkers above.
To verify SSL, connect to any Linux server via SSH and use the instructions below:
IMAP via SSL using port 993:
  1. connect to a mail server using openssl:
    # openssl s_client -showcerts -connect mail.example.com:993 -servername mail.example.com
  2. Check output and make sure that a valid certificate is shown:
    CONFIG_TEXT: Server certificate
    subject=/OU=Domain Control Validated/OU=PositiveSSL/CN=mail.example.com
    issuer=/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=PositiveSSL CA 2
  3. Make sure that you received IMAP server response:
    CONFIG_TEXT: * OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA AUTH=CRAM-MD5 AUTH=PLAIN IDLE ACL ACL2=UNION] Courier-IMAP ready. Copyright 1998-2004 Double Precision, Inc. See COPYING for distribution information.
POP3 via SSL using port 995:
  1. Connect to a mail server using openssl:
    # openssl s_client -showcerts -connect mail.example.com:995 -servername mail.example.com
  3. Make sure that you received POP3 server response:
    CONFIG_TEXT: +OK Hello there. 1793.1385684315@localhost.localdomain
SMTP via SSL using port 465:
    # openssl s_client -showcerts -connect mail.example.com:465 -servername mail.example.com
  3. Make sure that you received SMTP server response:
    CONFIG_TEXT: 220 mail.example.com ESMTP Postfix
SMTP via TLS/StartTLS using port 25 or 587
Note: To use port 587 the submission port should be enabled in Plesk:
    # openssl s_client -starttls smtp -showcerts -connect mail.example.com:25 -servername mail.example.com
    CONFIG_TEXT: 250 DSN
2 comments
Date Votes
  • Can you add a link to an article to help me figuring out how to fix this if it is not working?
    1
  • Hans Moviat
    The article is intended for obtaining information. After getting results, you can begin troubleshoot using the gathered info.
    -2
