How to verify that SSL for IMAP/POP3/SMTP works and a proper certificate is installed?
Using online checkers
Check SSL using online tools:
Using a Linux server
Any Linux server can be used for these tests. If you do not have a Linux server, use the online checkers above.
To verify SSL, connect to any Linux server via SSH and use the instructions below:
connect to a mail server using
openssl
:# openssl s_client -showcerts -connect mail.example.com:993 -servername mail.example.com
Check output and make sure that a valid certificate is shown:
CONFIG_TEXT: Server certificate
subject=/OU=Domain Control Validated/OU=PositiveSSL/CN=mail.example.com
issuer=/C=GB/ST=Greater Manchester/L=Salford/O=COMODO CA Limited/CN=PositiveSSL CA 2 -
Make sure that you received IMAP server response:
CONFIG_TEXT: * OK [CAPABILITY IMAP4rev1 UIDPLUS CHILDREN NAMESPACE THREAD=ORDEREDSUBJECT THREAD=REFERENCES SORT QUOTA AUTH=CRAM-MD5 AUTH=PLAIN IDLE ACL ACL2=UNION] Courier-IMAP ready. Copyright 1998-2004 Double Precision, Inc. See COPYING for distribution information.
Connect to a mail server using
openssl
:# openssl s_client -showcerts -connect mail.example.com:995 -servername mail.example.com
Make sure that you received POP3 server response:
CONFIG_TEXT: +OK Hello there. 1793.1385684315@localhost.localdomain
openssl
:# openssl s_client -showcerts -connect mail.example.com:465 -servername mail.example.com
Make sure that you received SMTP server response:
CONFIG_TEXT: 220 mail.example.com ESMTP Postfix
Note: To use port 587 the submission port should be enabled in Plesk:
openssl
:# openssl s_client -starttls smtp -showcerts -connect mail.example.com:25 -servername mail.example.com
CONFIG_TEXT: 250 DSN
2 comments
Can you add a link to an article to help me figuring out how to fix this if it is not working?
Hans Moviat
The article is intended for obtaining information. After getting results, you can begin troubleshoot using the gathered info.
