Articles in this section
Web statistics are not updated automatically in Plesk for Windows but manual web statistics calculation works correctly
Plesk for Windows kb: technical ABT: Group B
  • Plesk for Windows
Going to Windows > Task Scheduler, the scheduled task Plesk Scheduler Task - Daily web statistics analyzers run task is misconfigured.
  1. Connect to the server via RDP.
  2. Go to Task Scheduler > Task Scheduler Library and select one of the following use cases:
    Scheduled task doesn't exist
    Start a command prompt as Administrator and run the following command to recreate the scheduled task:
    C:\> "%plesk_bin%\crontabmng.exe" create-web-stat-executor-task
    Scheduled task is disabled
    Right-click on the scheduled task and press Enable:
    Click Install
    A scheduled task is stuck
    In the case that the scheduled task is stuck with Running status, restart the server to make sure the process is free up properly
    A Scheduled task has an incorrect path to the executable file specified
    Right-click on the scheduled task and press Properties.
    Navigate to Actions and edit the "Add arguments" field so it has a valid path to the "web_statistics_executor.exe":
    CONFIG_TEXT: Update to path containing web_statistics_executor.exe:
    /c "C:\Program Files (x86)\Plesk\admin\bin\runtask.exe" "--mail=jdoe@example.com" "--application=C:\Program Files (x86)\Plesk\admin\bin\web_statistics_executor.exe" "--parameters=""
  3. To calculate the traffic statistics for all the domains and verify the issue was solved, Right-click on the scheduled task and press Run. Once the scheduled task will finish, log in to Plesk GUI and verify that the Traffic statistics are displayed correctly.
