Articles in this section
RAM and CPU are not available in Resource Controller (cgroups) on Debian 8
DoNotDelete:docref kb: technical ABT: Group B
  • RAM and CPU are not available in Resource Controller (cgroups) on Debian 8.
  • Following entries in /var/log/plesk/panel.log
    CONFIG_TEXT: resctrl failed: CPU quota limit does not support this OS configuration Failure to parse command line arguments on option: --cpu-quota 20
Bug in Debian 8: its kernel does not support the cgroups CPU and RAM resource usage.
Note: This article is intended for use by server administrators. In case there is no administrative SSH access to the server, contact the server administrator or server provider.
As a workaround, install the newer kernel version from the debian-backports repository:
  1. Connect to the server using SSH.
  2. Enable debian-backports repo:
    # echo deb http://http.debian.net/debian jessie-backports main > /etc/apt/sources.list.d/jessie-backports.list
  3. Run the following commands to update kernel:
    # apt-get update
    # apt-get -t jessie-backports install linux-image-amd64
  4. Open /etc/default/grub in any text editor and set the following parameters:
    CONFIG_TEXT: GRUB_CMDLINE_LINUX_DEFAULT="cgroup_enable=memory swapaccount=1"
    GRUB_CMDLINE_LINUX="cgroup_enable=memory swapaccount=1"
  5. Reboot the server
