Articles in this section
How to automatically issue Let's Encrypt certificates for newly created domains?
Plesk for Windows kb: how-to Plesk for Linux ext: le ABT: Group B
  • Plesk for Linux
  • Plesk for Windows
How to enable/disable automatic issuing Let's Encrypt certificates for newly created domains?
  1. Log into Plesk.
  2. Enable/disable Service Plans > click on desired service plan > Additional Services > Let's Encrypt or SSL It > Keep websites secured with free SSL/TLS Certificates:
    Click Install
    Click Install
  3. Click OK.
Let's Encrypt and SSL It! extensions have a scheduled task named keep-secured.php visible in Tools & Settings > Scheduled Tasks: ​​
This task is running hourly. The certificate for new domains will be issued on the next run of the keep-secured.php task.
If the Admin edition is used the following command helps:
# plesk bin service_plan --add-custom-plan-item 'Admin simple' -custom-plan-item-name "urn:ext:sslit:plan-item-sdk:keep-secured"
Additional information:
If Let's Encrypt is enabled in Additional Services of a service plan, will existing domains be secured?
