Articles in this section
How to install WordPress with custom settings on Plesk server?
Plesk for Windows kb: how-to Plesk for Linux ext: wptk
  • Plesk for Linux
  • Plesk for Windows
When WordPress instance is deployed via WP Toolkit in Plesk, database name and database username are set automatically.
How to define such settings manually?
How to select version of WordPress before the installation?
Go to Domains > example.com > Install WordPress or Domains > example.com > WordPress > Install and set the required settings (options under Database and Automatic Update Settings are hidden by default, so unfold these options if necessary):
  1. The button 'Install WordPress'
  2. 'Install WordPress' screen where custom settings are available as well
