Adding remote Bitbucket repository to Plesk in Domains > example.com > Git fails:
PLESK_ERROR: Deploying files to example.com
Public key for the server at 'bitbucket.org' is already known in '/var/www/vhosts/example.com/.ssh/git_known_hosts'.
Permission denied (publickey).
fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
The SSH key was generated with passphrase protection.
Support of SSH keys with passphrase protection is yet to be implemented in the Plesk Git extension.
Vote for the corresponding feature suggestion on our UserVoice portal.
The top-ranked suggestions are likely to be implemented in one of the next versions of the extension.
Until this feature is implemented, the following workaround can be used:
Generate an SSH key without passphrase protection in the Bitbucket account.
Connect to the server via using SSH.
Rename the files
id_rsaandid_rsa.pubin/var/www/vhosts/example.comin case they are exist:# mv /var/www/vhosts/example.com/id_rsa{,.orig}
# mv /var/www/vhosts/example.com/id_rsa.pub{,.orig} -
Place the files
id_rsaandid_rsa.pubcreated on step 1 into/var/www/vhosts/example.com. -
Go to Domains > example.com > Git and add the Bitbucket repository.
It just doesn't work can you please help?
