- Plesk for Windows
How to customize the WordPress maintenance page with WP Toolkit?
Maintenance mode pages can be personalized for each domain individually, and on a main template that applies to the entire server. Detailed information can be found in: Customizing the maintenance page | Plesk Obsidian documentation.
Open WP Toolkit, expand the site to customize, and press the settings
button next to Maintenance mode
Press Customize
Go to
wp-content/maintenanceand edittemplate.phtml -
Press OK
Note: The default (or customized) server-wide maintenance page template will only be applied to WordPress sites that have never been put into maintenance mode. To apply it to a WordPress site that has already been put into maintenance mode, select Restore Default from the Maintenance Mode configuration menu.
Connect to the server via RDP
Make a copy of the current template:
%plesk_dir%\var\modules\wp-toolkit\maintenance\template.phtml -
Edit
%plesk_dir%\var\modules\wp-toolkit\maintenance\template.phtmlin a text editor.
