Articles in this section
Website is slow or does not work: connect() to php-fpm.sock failed (11: Resource temporarily unavailable)
Plesk for Linux kb: technical ABT: Group B
  • Plesk for Linux
  • Website exampe.com is slow or not available:
    PLESK_INFO: 502 Bad Gateway
    OR
    PLESK_INFO: 504 Gateway Time-out error
  • MaxClients parameter tuning does not help.
  • Errors are logged to /var/www/vhosts/system/example.com/logs/proxy_error_log very fastly:
    CONFIG_TEXT: [error] 31843#0: *30563813 connect() to unix:///var/www/vhosts/system/example.com/php-fpm.sock failed (11: Resource temporarily unavailable) while connecting to upstream, client: 203.0.113.2, server: example.com, request: "HEAD // HTTP/1.1", upstream: "fastcgi://unix:///var/www/vhosts/system/example.com/php-fpm.sock:", host: "www.example.com"
  • Website nginx error log analysis shows huge amount of HTTP requests from particular addresses:
    # tail -n 10000  /var/www/vhosts/system/example.com/logs/proxy_error_log |cut -f 19 -d ' '|sort|uniq -c|sort -nr|more
      3566 203.0.113.2,
      3158 203.0.113.3,
      2162 203.0.113.4,
The website is under DDoS attack.
As a workaround, login to Plesk server via SSH and block the IP addresses sending huge amount of requests:
# iptables -I INPUT 1 -p tcp -s 203.0.113.2 -j DROP
# iptables -I INPUT 1 -p tcp -s 203.0.113.3 -j DROP
# iptables -I INPUT 1 -p tcp -s 203.0.113.4 -j DROP
As a permanent solution, consider installing Plesk extensions mentioned in the article below:
What DDoS protection tools does Plesk support?
Additional information
MaxClients setup can be found here: MaxClients
