How to disable specific Web Application Firewall ModSecurity rules in Plesk
2 comments
    Pascal Devif (Edited )
    Ok thx.
    If you want to disable a rule for a specific folder use this :
    <IfModule mod_security2.c>
        # General rules
        SecResponseBodyLimit 536870912
        SecRuleRemoveById 999777
        # A comment
        <Directory /var/www/vhosts/domain.tld/httpdocs/yourfolder>
            SecRuleRemoveById 999888
        </Directory>
    </IfModule>
    Replace domain.tld and yourfolder with correct informations for you ...
    1
    vincenzo pasqualino
    There is some list of trusted ID rules to be included at a general level
