- Plesk for Windows
Issuing a wildcard Let's Encrypt certificate in Plesk in Domains > example.com > SSL/TLS Certificates > Install fails:
Error: Could not issue a Let's Encrypt SSL/TLS certificate for example.com. Authorization for the domain failed.
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/authz/zEHPSbB4eUyIomzu9qynFouNGrIgiUlJZ755z_Kx4kY.
Details:
Type: urn:ietf:params:acme:error:dns
Status: 400
Detail: DNS problem: NXDOMAIN looking up TXT for _acme-challenge.example.com
The TXT DNS record for the hostname _acme-challenge.example.com is not available globally:
# nslookup -type=TXT _acme-challenge.example.com
Server: 8.8.8.8
Address: 8.8.8.8#53
** server can't find _acme-challenge.example.com: NXDOMAIN
Start issuing a new wildcard Let's Encrypt certificate in Domains > example.com > SSL/TLS Certificates > Install - the following notification screen will appear:
Proceed in accordance with where the domain's DNS zone is hosted:
DNS zone of the domain is hosted on the Plesk server-
Wait until the DNS propagation is completed and the required TXT record for the hostname _acme-challenge.example.com is available globally. The availability of this record can be checked on resources like https://dnschecker.org/.
Press the Reload button in the notification screen from step 2.
DNS zone of the domain is hosted on external DNS hosting-
On the external DNS hosting, add the TXT record for the hostname _acme-challenge.example.com (or just for _acme-challenge on some DNS providers) using the value from the notification screen from step 2.
