The text files cannot be opened by the
vimeditor, with the error below:E557: Cannot open termcap file
Characters are not removed with the
backspacebutton, instead aspacecharacter is written in SSH -
In an attempt to read a file with
lessutility, after it is not possible to exit from the opened file. -
In SSH Terminal extension the arrow keys do not work as expected to navigate in the SSH session
Plesk bug with ID #PPPM-12254, which is planned to be fixed in a future Plesk version.
Until the bug is fixed, apply the following workaround:
Download the update_chroot script to the server
Add the terminal capabilities to the chroot template by executing the update_chroot script as below:
# ./update-chroot.sh --termcap
Apply the new template:
For the specific domain:
# ./update-chroot.sh --apply example.com
Note: replace
example.comwith the name of the required domain. -
For all domains:
# ./update-chroot.sh --apply all
