How to enable Web Presence Builder for all websites?
Web Presence Builder option should be available for all domains after Web Presence Builder installed if it is not restricted on Service Plan or Subscription level.
Log in to Plesk
Check that Web Presence Builder is installed by running the command:
# plesk installer --show-hidden-components
If Web Presence Builder is installed, check that the publishing feature is available for Plesk license at Tools & Settings > License Management. If the parameter Sites published with Web Presence Builder equals zero, customers will not be able to use Web presence Builder.
If the Web Presence Builder limit on the license is not zero, the ability to edit the site is determined by the service plan. Go to Service Plans > (Select service plan) > Resources
tab and set the desired limit for the Sites published with Web Presence Builder parameter: -
A subscription inherits the settings and limits of its service plan. However, subscription limits can be customized. If the Presence Builder button is not shown on some domains, check that the limit of the Sites published with Web Presence Builder parameter has not been changed. Go to Home > Subscriptions > (Select subscription) > click on the "Customize" button (Check the limit for the "Sites published with Web Presence Builder" parameter)
