Articles in this section
Watchdog script "secur-check" fails in Plesk: Zend_Exception: No entry is registered for key 'container'
kb: bug kb: fixed Plesk for Linux
  • Plesk for Linux
  • The scheduled task /usr/local/psa/libexec/modules/watchdog/cp/secur-check fails with:
    PLESK_INFO: ERR [panel] No entry is registered for key 'container':
    0: /usr/local/psa/admin/plib/vendor/plesk/zf1/library/Zend/Registry.php:147
    Zend_Registry::get(string 'container')
    1: /usr/local/psa/admin/plib/Plesk/Log/UtilExec.php:34
    Plesk_Log_UtilExec->start(string 'rsecurcheck', array, string '', boolean false)
    2: /usr/local/psa/admin/plib/common_func.php:123
    util_exec(string 'rsecurcheck', array, array, string 'msg', string 'watchdog', boolean true)
    3: /usr/local/psa/admin/plib/common_func.php:35
    mod_smart_exec(string 'watchdog', string 'rsecurcheck', array, array, string 'msg')
    4: /usr/local/psa/admin/plib/modules/watchdog/wdlib.php:1157
    wd__exec_wd_util(string 'rsecurcheck', array, array)
    5: /usr/local/psa/libexec/modules/watchdog/cp/secur-check:10
    ERROR: Zend_Exception: No entry is registered for key 'container' (Registry.php:147)
  • Plesk Administrator receives an email notification with the same error message.
Product issue:
  • #PPPM-13385 "Emails with daily reports from the “Watchdog” extension now contain correct data instead of error messages again."
    Fixed in:
Workaround
If update is not possible for some reason you may try the following
workaround
As a workaround, apply a custom fix:
  1. Connect to the Plesk server via SSH.
  2. Download the patched file in zip:
    # wget https://plesk.zendesk.com/hc/article_attachments/12376925990039/wdcplib.zip
  3. Extract the file:
    # unzip wdcplib.zip
  4. Rename the original file:
    # mv /usr/local/psa/admin/plib/modules/watchdog/wdcplib.php /usr/local/psa/admin/plib/modules/watchdog/wdcplib.php.orig
  5. Move the patched file:
    # mv wdcplib.php /usr/local/psa/admin/plib/modules/watchdog
